Hypestar
Sep 13, 2018Follower
M4300 IGMP snooping
Hello,
i have problems with configuring IGMP Snooping on my Netgear M4300 switch.
Heres a link with pictures of my current configuration: https://imgur.com/a/N3UaYIK
All devices ar...
- Oct 02, 2018Hi All,
We have worked out the issue with Netgear Support. Turns out the Bonjour service is disrupting MDNS between the TX and RX.
Disabling the bonjour service fixed it.
VistaICT
Sep 17, 2018Star
Our multicast broke today after upgrading to firmware 12.0.7.7, downgrading to 12.0.4.9 resumed normal multicast functionality.
Also noticed the 'snoopTask' process was consuming 99% CPU on all versions higher than 12.0.4.9
- BretDSep 18, 2018Administrator
Thanks for bringing this to our attention. I've reached out to the support and engineering team to investigate immediately.
- atianSep 18, 2018Aspirant
Could you provide the following:
1) network topology including the router, IPTV
2) go to the maintanence->export->HTTP file export, select 'techsupport file' and click the apply button.
3) capture the packets on the port connected to the IPTV Streaming server.
- VistaICTSep 18, 2018Star
I have opened case #40496719 with support regarding this issue. For those interested I have done a basic test of both firmware versions (12.0.4.9 & 12.0.7.7)
1) boot switch using firmware to test
2) erase startup-config
3) reboot switch
4) increase MTU on interfaces 1/0/1 & 1/0/2 where my multicast devices are attached
5) check MFDB
On the 12.0.7.7 firmware my multicast receiver does not join the group. On 12.0.4.9 it does.
Here is a diff showing the tech-support for 12.0.4.9 (left) and 12.0.7.7 (right)
