Hypestar
Sep 13, 2018Follower
M4300 IGMP snooping
Hello,
i have problems with configuring IGMP Snooping on my Netgear M4300 switch.
Heres a link with pictures of my current configuration: https://imgur.com/a/N3UaYIK
All devices ar...
- Oct 02, 2018Hi All,
We have worked out the issue with Netgear Support. Turns out the Bonjour service is disrupting MDNS between the TX and RX.
Disabling the bonjour service fixed it.
VistaICT
Sep 30, 2018Star
Here's some PCAPs using different firmware 12.0.4.9 and 12.0.7.7: https://ufile.io/vwnha (can't upload them here)
This was done on a stack of M4300-52G-POE switches and includes a TechSupport dump
The switches are always in factory configuration
I have also tested firmware 12.0.7.8 today and the problem still exists.
You'll notice in the 12.0.7.7 the receiver is sending MDNS queries to 224.0.0.251 but never sees a response. In 12.0.4.9 the response is seen followed by a peer-to-peer TCP negotiation of metadata/keys and then video traffic starts flowing.
169.254.3.3 is the transmitter
169.254.6.7 is the receiver
225.0.100.3 is the multicast group the transmitter is sending traffic to and the receiver is trying to join
VistaICT
Oct 02, 2018Star
Hi All,
