logicallysynced
May 06, 2018Tutor
M4300 Inter-VLAN routing
Hi there, I've been trying to setup a M4300-8X8F with inter-vlan routing for hours now to no avail. I'm running the latest firmware (12.0.4.8) and have followed all the instructions found in the U...
- May 06, 2018
I can't see the picture (it takes a while for the moderators to approve it for display).
It's kinda hard to tell where the IP addresses are assigned. I'm guessing that 192.168.50.254 is assigned to the M4300? If yes, then are the static routes for the VLAN subnets pointing to 192.168.50.254?
TheEther
May 06, 2018Guru
Retired_Member
May 06, 2018Hi logicallysynced,
Welcome to the community!
Could you please do more test as below for further analysis:
1. From Firewall, check if ping 10.0.10.254/192.168.10.254 success?
2. Run CLI command 'show ip interface brief' on switch
3. Run CLI command 'show ip route' on switch
4. It's better if you can provide the tech-support file of the switch
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
Hope it helps!
EricZ
NETGEAR employee
