logicallysynced
May 06, 2018Tutor
M4300 Inter-VLAN routing
Hi there, I've been trying to setup a M4300-8X8F with inter-vlan routing for hours now to no avail. I'm running the latest firmware (12.0.4.8) and have followed all the instructions found in the U...
- May 06, 2018
I can't see the picture (it takes a while for the moderators to approve it for display).
It's kinda hard to tell where the IP addresses are assigned. I'm guessing that 192.168.50.254 is assigned to the M4300? If yes, then are the static routes for the VLAN subnets pointing to 192.168.50.254?
TheEther
May 06, 2018Guru
logicallysynced
May 07, 2018Tutor
Ah this was the problem, the default gateway was set to the VLAN SVI and not the gateway VLAN's SVI. Thanks so much!!
