purplewater6
Dec 21, 2018Aspirant
M4300 Port Mirror, retain VLAN Tag
New to NETGEAR switches. Basically I would like to use a port mirror to send multiple ports to a probe port. I would like to vlan tag traffic on each port and have these tags remain on the traffic wh...
JohnC_V
Dec 28, 2018NETGEAR Employee Retired
Hi purplewater6,
Welcome to our community! :)
May you be able to check if the mirrored port is also a tagged port? It seems that you cannot see anything from that port unless it is also a part of that VLAN.
purplewater6
Dec 28, 2018Aspirant
Just to clarify you need the probe port to be in the same VLAN and Tagged?
Also I do not have any VLAN routing setup (any layer 3), I wouldn’t think this is required.
- JohnC_VJan 04, 2019NETGEAR Employee Retired
No need for VLAN routing on port mirroring. I inquired your case and they suggested to open a ticket on NETGEAR support so that we can further investigate what is the cause of this issue.
