purplewater6
Dec 21, 2018Aspirant
M4300 Port Mirror, retain VLAN Tag
New to NETGEAR switches. Basically I would like to use a port mirror to send multiple ports to a probe port. I would like to vlan tag traffic on each port and have these tags remain on the traffic wh...
purplewater6
Dec 28, 2018Aspirant
Just to clarify you need the probe port to be in the same VLAN and Tagged?
Also I do not have any VLAN routing setup (any layer 3), I wouldn’t think this is required.
JohnC_V
Jan 04, 2019NETGEAR Employee Retired
No need for VLAN routing on port mirroring. I inquired your case and they suggested to open a ticket on NETGEAR support so that we can further investigate what is the cause of this issue.
