XanderVR
Jan 30, 2018Aspirant
M4300 Setting LAG and VLAN
Hello all, just a quick question, as I am getting some funny issues with VLANs on my M4300's. (for example VLAN 1 devices getting IP from VLAN 10 DHCP....) If I make a LAG of 2 ports (49 and ...
- Feb 01, 2018
Hi XanderVR,
Basically, LAGs can be also configured as tagged or untagged. If you wanted to passthrough multiple VLANs, then you may need to set it up as trunk or tagged. You may now remove the T or U ports in ports 49-50, except the LAG.
JohnC_V
Feb 01, 2018NETGEAR Employee Retired
Hi XanderVR,
