XanderVR
Jan 30, 2018Aspirant
M4300 Setting LAG and VLAN
Hello all, just a quick question, as I am getting some funny issues with VLANs on my M4300's. (for example VLAN 1 devices getting IP from VLAN 10 DHCP....) If I make a LAG of 2 ports (49 and ...
- Feb 01, 2018
Hi XanderVR,
Basically, LAGs can be also configured as tagged or untagged. If you wanted to passthrough multiple VLANs, then you may need to set it up as trunk or tagged. You may now remove the T or U ports in ports 49-50, except the LAG.
JohnC_V
Feb 05, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- XanderVRFeb 05, 2018AspirantThis basically answered my question and solved my problem (partially, but that has nothing to do with lags)
I now have removed all VLAN from the individual ports and ser them as general.
I have set the lag as general and put all VLAN on theblag.
