KelvinFu
Nov 18, 2016Aspirant
M4300 SFP Port Trunking Issues
Hi all, I recently purchased 2 new M4300 and form a stack. After stacking the SW, I started to setup the switch as normal, the management VLAN, IP, the rest of vlan, subnet of those VLAN. Since i...
- Nov 23, 2016
Hi Kelvin,
It's a good news that the failover problem resolved.:smileyhappy:
Let's carry on the VRRP scenario.
I have checked the maintenance file just you sent to us.
1) Congratulation!The address (192.168.100.2 ) is the virtual IP address of VRRP on Firewall.
Because this IP have same prefix mac-address header just like (00:00:5E:00:xx:xx).
It's the standard of VRRP for mac-address behavior.
2) Good finding! The "Link state detection” is very useful for VRRP status.
So we need to set the IP for heartbeat on each Firewall that could monitor VRRP all the time.
But 192.168.100.1 is not the heartbeat address for Firewall that is VLAN interface on M4300-Stack.
So Could you set an IP address on Firewall A and B that is not VRRP protocol.
Such as:
192.168.100.10 /24 on Firewall A.
192.168.100.20 /24 on Firewall B.
Then,
Set Link state detection IP address to 192.168.100.20 on Firewall A.
Set Link state detection IP address to 192.168.100.10 on Firewall B.
That will make Firewall detect each other with this configuration.
3) Could you share me the configuration page or command on your Firewall about LAG/Port/IP address/VRRP configuration?
The private message is RECOMMENDED.
I'm not very professional on Firewall of other company.
Just want to help analyze.:smileyhappy:
Look forward to your reply.
Daniel.
KelvinFu
Nov 19, 2016Aspirant
Hi Laurent,
Thx for the reply, since i'm off from work, I will upload the file on Moday. before I have the runnnig for you, I would like to share more info to you first.
We have a HA design by enabling VRRP in Firewall and stacking in Layer 3 Core SW, also we have Layer 2 access SW in each floor and connect it to both Core stack member.
In this stage, we are not starting on the configurion of Layer 2, instead we focus on Layer 3.
We have totally 7 VLAN in core sw
1 - default - 192.168.200.0/24 - 192.168.200.1 as vlan interface (I assumed this is the native vlan as same as cisco? so i don't have check on it since i'm not very familiar with the CLI)
2 - vlan 2 - 192.168.0.0/24 - 192.168.0.1 as vlan interface
3 - vlan 3 - 192.168.1.0/24 - 192.168.1.1 as vlan interface
4 - vlan 4 - 192.168.2.0/23 - 192.168.2.1 as vlan interface
5 - vlan 5 - 192.168.4.0/23 - 192.168.4.1 as vlan interface
6 - vlan 6 - 192.168.6.0/24 - 192.168.6.1 as vlan interface
7 - vlan 7 - 192.168.100.0/30 - 192.168.100.1 as vlan interface (connect to VRRP firewall group, port 9 to firewall A, and port 10 to firewall B)
I then set port 2-10 as a trunking port by using CLI, port 1 in both units are connected by stacking cable. After the setting was finished, I verified the ports on WebGUI to make sure it was being trunked, but with no luck, port 2-8 was label as "U" while 9-10 are nromal to be marked as "T", the only difference between 9-10 and 2-8 is that 9-10 are ethernet port while 2-8 are SFP port. When I saw this abnormal thing, I manually marked the port 2-8 to "T" and clicked apply. Then....it wasn't applied as you knew and changed back to "U". The switches are brand new, so I didn't have another setting before this, also I had reset the switch to factory default before I made those change. So I don't think I did have configure on those ports.
KelvinFu
Nov 20, 2016Aspirant
Unit 1
!Current Configuration:
!System Description "M4300-8X8F ProSAFE 8-port 10GBASE-T and 8-port 10G SFP+, 12.0.2.6, 1.0.0.7"
!System Software Version "12.0.2.6"
!System Up Time "2 days 22 hrs 7 mins 47 secs"
!Additional Packages QOS,Multicast,IPv6,IPv6 Management,Stacking,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
hostname "CoreSW-1"
set gvrp adminmode
enable password f6f136b1793bd7a9da7f3edfac514c690156a6088107f654742867e597514667e20688da5f2057335dc3da47d4d669ad616f9d416d4a700979e4146ee8f43119 encrypted
serviceport protocol none
serviceport ip 10.251.251.251 255.255.255.0 0.0.0.0
vlan database
vlan 2-7
vlan name 2 "Server"
vlan name 3 "CCTV"
vlan name 4 "Operation"
vlan name 5 "Academic"
vlan name 6 "Public"
vlan name 7 "RoutingZone"
vlan routing 1 1
vlan routing 2 2
vlan routing 3 3
vlan routing 4 4
vlan routing 5 5
vlan routing 6 6
vlan routing 7 7
vlan association subnet 192.168.0.0 255.255.255.0 2
vlan association subnet 192.168.1.0 255.255.255.0 3
vlan association subnet 192.168.2.0 255.255.254.0 4
vlan association subnet 192.168.4.0 255.255.254.0 5
vlan association subnet 192.168.6.0 255.255.255.0 6
vlan association subnet 192.168.100.0 255.255.255.0 7
vlan association subnet 192.168.200.0 255.255.255.0 1
exit
configure
stack
member 1 6
member 2 6
exit
switch 1 priority 1
switch 2 priority 2
slot 1/0 6
set slot power 1/0
no set slot disable 1/0
slot 2/0 6
set slot power 2/0
no set slot disable 2/0
username "admin" password 0cc141558cdf3fe2475b8528c2d8d41e00d1351e56d2f2984581aac7521798d7d1ad50eebe599947ee39125507c38a81f3ac18f4f7f2c9a0608cd2c56607cbf1 level 15 encrypted
line console
exit
line telnet
exit
line ssh
exit
snmp-server sysname "CoreSW-1"
ip access-list Public-ACL
deny ip 192.168.6.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 192.168.6.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.6.0 0.0.0.255 192.168.2.0 0.0.1.255
deny ip 192.168.6.0 0.0.0.255 192.168.4.0 0.0.1.255
permit ip any any
exit
interface 1/0/1
vlan participation auto 1
exit
interface 1/0/2
bandwidth 10000000
set gvrp interfacemode
switchport mode trunk
switchport trunk allowed vlan 1-7
routing
ip mtu 1500
exit
interface 1/0/3
bandwidth 10000000
vlan tagging 1
routing
ip mtu 1500
exit
interface 1/0/4
bandwidth 1000000
routing
ip mtu 1500
exit
interface 1/0/5
bandwidth 10000000
routing
ip mtu 1500
exit
interface 1/0/6
bandwidth 100000
routing
ip mtu 1500
exit
interface 1/0/7
bandwidth 10000000
routing
ip mtu 1500
exit
interface 1/0/8
bandwidth 100000
routing
ip mtu 1500
exit
interface 1/0/9
switchport mode access
switchport access vlan 7
vlan tagging 3
exit
interface 1/0/10
exit
interface 1/0/11
vlan pvid 7
vlan participation include 7
exit
interface 1/0/12
vlan pvid 7
exit
interface 1/0/13
vlan pvid 7
exit
interface 1/0/14
vlan pvid 7
exit
interface 1/0/15
exit
interface 1/0/16
exit
interface 2/0/1
exit
interface 2/0/2
exit
interface 2/0/3
exit
interface 2/0/4
exit
interface 2/0/5
exit
interface 2/0/6
exit
interface 2/0/7
exit
interface 2/0/8
exit
interface 2/0/9
exit
interface 2/0/10
exit
interface 2/0/11
exit
interface 2/0/12
exit
interface 2/0/13
exit
interface 2/0/14
exit
interface 2/0/15
exit
interface 2/0/16
exit
interface lag 1
exit
interface lag 2
exit
interface lag 3
exit
interface lag 4
exit
interface lag 5
exit
interface lag 6
exit
interface lag 7
exit
interface lag 8
exit
interface lag 9
exit
interface lag 10
exit
interface lag 11
exit
interface lag 12
exit
interface lag 13
exit
interface lag 14
exit
interface lag 15
exit
interface lag 16
exit
interface lag 17
exit
interface lag 18
exit
interface lag 19
exit
interface lag 20
exit
interface lag 21
exit
interface lag 22
exit
interface lag 23
exit
interface lag 24
exit
interface lag 25
exit
interface lag 26
exit
interface lag 27
exit
interface lag 28
exit
interface lag 29
exit
interface lag 30
exit
interface lag 31
exit
interface lag 32
exit
interface lag 33
exit
interface lag 34
exit
interface lag 35
exit
interface lag 36
exit
interface lag 37
exit
interface lag 38
exit
interface lag 39
exit
interface lag 40
exit
interface lag 41
exit
interface lag 42
exit
interface lag 43
exit
interface lag 44
exit
interface lag 45
exit
interface lag 46
exit
interface lag 47
exit
interface lag 48
exit
interface lag 49
exit
interface lag 50
exit
interface lag 51
exit
interface lag 52
exit
interface lag 53
exit
interface lag 54
exit
interface lag 55
exit
interface lag 56
exit
interface lag 57
exit
interface lag 58
exit
interface lag 59
exit
interface lag 60
exit
interface lag 61
exit
interface lag 62
exit
interface lag 63
exit
interface lag 64
exit
interface lag 65
exit
interface lag 66
exit
interface lag 67
exit
interface lag 68
exit
interface lag 69
exit
interface lag 70
exit
interface lag 71
exit
interface lag 72
exit
interface lag 73
exit
interface lag 74
exit
interface lag 75
exit
interface lag 76
exit
interface lag 77
exit
interface lag 78
exit
interface lag 79
exit
interface lag 80
exit
interface lag 81
exit
interface lag 82
exit
interface lag 83
exit
interface lag 84
exit
interface lag 85
exit
interface lag 86
exit
interface lag 87
exit
interface lag 88
exit
interface lag 89
exit
interface lag 90
exit
interface lag 91
exit
interface lag 92
exit
interface lag 93
exit
interface lag 94
exit
interface lag 95
exit
interface lag 96
exit
interface lag 97
exit
interface lag 98
exit
interface lag 99
exit
interface lag 100
exit
interface lag 101
exit
interface lag 102
exit
interface lag 103
exit
interface lag 104
exit
interface lag 105
exit
interface lag 106
exit
interface lag 107
exit
interface lag 108
exit
interface lag 109
exit
interface lag 110
exit
interface lag 111
exit
interface lag 112
exit
interface lag 113
exit
interface lag 114
exit
interface lag 115
exit
interface lag 116
exit
interface lag 117
exit
interface lag 118
exit
interface lag 119
exit
interface lag 120
exit
interface lag 121
exit
interface lag 122
exit
interface lag 123
exit
interface lag 124
exit
interface lag 125
exit
interface lag 126
exit
interface lag 127
exit
interface lag 128
exit
interface vlan 1
routing
ip address 192.168.200.1 255.255.255.0
exit
interface vlan 2
routing
ip address 192.168.0.1 255.255.255.0
exit
interface vlan 3
routing
ip address 192.168.1.1 255.255.255.0
exit
interface vlan 4
routing
ip address 192.168.2.1 255.255.254.0
exit
interface vlan 5
routing
ip address 192.168.4.1 255.255.254.0
exit
interface vlan 6
routing
ip address 192.168.6.1 255.255.255.0
exit
interface vlan 7
routing
ip address 192.168.100.1 255.255.255.252
exit
ip management vlan 1 192.168.200.1 255.255.255.0
router rip
exit
router ospf
exit
ipv6 router ospf
exit
ip route 0.0.0.0 0.0.0.0 192.168.100.2
exit
- KelvinFuNov 20, 2016Aspirant
Unit 2
hostname "CoreSW-1"
set gvrp adminmode
vlan database
vlan 2-7
vlan name 3 "CCTV"
vlan routing 1 1
vlan routing 2 2
vlan routing 3 3
vlan routing 4 4
vlan routing 5 5
vlan routing 6 6
vlan routing 7 7
exit
configure
stack
member 1 6
member 2 6
exit
switch 1 priority 1
switch 2 priority 2
slot 1/0 6
set slot power 1/0
slot 2/0 6
set slot power 2/0
line console
exit
line telnet
exit
line ssh
exit
permit ip any any
exit
interface 1/0/1
exit
interface 1/0/2
bandwidth 10000000
routing
ip mtu 1500
exit
interface 1/0/3
bandwidth 10000000
vlan tagging 1
routing
ip mtu 1500
exit
interface 1/0/4
bandwidth 1000000
routing
ip mtu 1500
exit
interface 1/0/5
bandwidth 10000000
routing
ip mtu 1500
exit
interface 1/0/6
bandwidth 100000
routing
ip mtu 1500
exit
interface 1/0/7
bandwidth 10000000
routing
ip mtu 1500
exit
interface 1/0/8
bandwidth 100000
routing
ip mtu 1500
exit
interface 1/0/9
vlan tagging 3
exit
interface 1/0/10
exit
interface 1/0/11
vlan pvid 7
exit
interface 1/0/12
vlan pvid 7
exit
interface 1/0/13
vlan pvid 7
exit
interface 1/0/14
vlan pvid 7
exit
interface 1/0/15
exit
interface 1/0/16
exit
interface 2/0/1
exit
interface 2/0/2
exit
interface 2/0/3
exit
interface 2/0/4
exit
interface 2/0/5
exit
interface 2/0/6
exit
interface 2/0/7
exit
interface 2/0/8
exit
interface 2/0/9
exit
interface 2/0/10
exit
interface 2/0/11
exit
interface 2/0/12
exit
interface 2/0/13
exit
interface 2/0/14
exit
interface 2/0/15
exit
interface 2/0/16
exit
interface lag 1
exit
interface lag 2
exit
interface lag 3
exit
interface lag 4
exit
interface lag 5
exit
interface lag 6
exit
interface lag 7
exit
interface lag 8
exit
interface lag 9
exit
interface lag 10
exit
interface lag 11
exit
interface lag 12
exit
interface lag 13
exit
interface lag 14
exit
interface lag 15
exit
interface lag 16
exit
interface lag 17
exit
interface lag 18
exit
interface lag 19
exit
interface lag 20
exit
interface lag 21
exit
interface lag 22
exit
interface lag 23
exit
interface lag 24
exit
interface lag 25
exit
interface lag 26
exit
interface lag 27
exit
interface lag 28
exit
interface lag 29
exit
interface lag 30
exit
interface lag 31
exit
interface lag 32
exit
interface lag 33
exit
interface lag 34
exit
interface lag 35
exit
interface lag 36
exit
interface lag 37
exit
interface lag 38
exit
interface lag 39
exit
interface lag 40
exit
interface lag 41
exit
interface lag 42
exit
interface lag 43
exit
interface lag 44
exit
interface lag 45
exit
interface lag 46
exit
interface lag 47
exit
interface lag 48
exit
interface lag 49
exit
interface lag 50
exit
interface lag 51
exit
interface lag 52
exit
interface lag 53
exit
interface lag 54
exit
interface lag 55
exit
interface lag 56
exit
interface lag 57
exit
interface lag 58
exit
interface lag 59
exit
interface lag 60
exit
interface lag 61
exit
interface lag 62
exit
interface lag 63
exit
interface lag 64
exit
interface lag 65
exit
interface lag 66
exit
interface lag 67
exit
interface lag 68
exit
interface lag 69
exit
interface lag 70
exit
interface lag 71
exit
interface lag 72
exit
interface lag 73
exit
interface lag 74
exit
interface lag 75
exit
interface lag 76
exit
interface lag 77
exit
interface lag 78
exit
interface lag 79
exit
interface lag 80
exit
interface lag 81
exit
interface lag 82
exit
interface lag 83
exit
interface lag 84
exit
interface lag 85
exit
interface lag 86
exit
interface lag 87
exit
interface lag 88
exit
interface lag 89
exit
interface lag 90
exit
interface lag 91
exit
interface lag 92
exit
interface lag 93
exit
interface lag 94
exit
interface lag 95
exit
interface lag 96
exit
interface lag 97
exit
interface lag 98
exit
interface lag 99
exit
interface lag 100
exit
interface lag 101
exit
interface lag 102
exit
interface lag 103
exit
interface lag 104
exit
interface lag 105
exit
interface lag 106
exit
interface lag 107
exit
interface lag 108
exit
interface lag 109
exit
interface lag 110
exit
interface lag 111
exit
interface lag 112
exit
interface lag 113
exit
interface lag 114
exit
interface lag 115
exit
interface lag 116
exit
interface lag 117
exit
interface lag 118
exit
interface lag 119
exit
interface lag 120
exit
interface lag 121
exit
interface lag 122
exit
interface lag 123
exit
interface lag 124
exit
interface lag 125
exit
interface lag 126
exit
interface lag 127
exit
interface lag 128
exit
interface vlan 1
routing
exit
interface vlan 2
routing
exit
interface vlan 3
routing
exit
interface vlan 4
routing
exit
interface vlan 5
routing
exit
interface vlan 6
routing
exit
interface vlan 7
routing
exit
router rip
exit
router ospf
exit
ipv6 router ospf
exit
exit- KelvinFuNov 20, 2016Aspirant
today I was going to reset both unit to factory default again. I found that the stack config and also the unit number will remain whether I reset it to factory default. I finaly run "switch 2 renumber 1" to force it to be "default", but I don't know whehter it is correct.
erase stack-config
erase startup-config
reload
en mode and then
switch 2 renumber 1 in unit 2
Here is my flow to setup the M4300, please correct me if I was wrong
1. change oob ip address in both switch to 10.251.251.251
2. change default vlan ip to 192.168.200.1
3. enable stack in port 1 in both switches
4. power-off both switches and connect them with the stack cable
5. power-on switch A and with until the webgui can be accessed
6. power-on switch B
7. the above steps are finished in WebGUI
8. connect my mini usb to the switch A
9. rename Switch A to CoreSW -1
10. setup password and enable password
11. create vlan 2 - 7 as I mentioned before
12. setup vlan interface
13. enable trunking in port 2-10
then i found the problems
the rest of parts are
setup GVRP
may be M-LAG I think?
