viknesh
Mar 13, 2018Aspirant
M4300 SFP Port Trunking Issues
Hi Planning to get M4300 switches for pabx implementation for multi campus environment. So incoming trunk line are both PSTN and E1 PRI ISDN. We have few buildings that we need to connect via n...
- Mar 17, 2018
Of course, yes.
schumaku
Mar 15, 2018Guru - Experienced User
Ok, then your set-up does make perfect sense. Are there plans to use the same network for data and voice?
viknesh
Mar 15, 2018Aspirant
Hi
The pabx system will also operate UCS (Unified Communications) which carry data to desktop to few (around 50) PC's for contact center operators. So yes, the switch should able to segment voice and data. Large part of it will be voice. To do this, possible to create Vlans to segment it?
Viknesh
- schumakuMar 17, 2018Guru - Experienced User
Of course, yes.
