knarfer's avatar
knarfer
m4300 stack-port errors
Hi,
we have a stack with 4 m4300-24x24F switches.
in the log files there are many (every minute) errors related to the stack ports ("errors detected on stack-port" and "Multiple consecutive errors detected on stack port").
what can be the problem?
regards
Frank
  • Hi knarfer
    This is likely a problem with either the stacking cable or modules (if you use SFP ports for the stacking).
    What stacking connection are you using?
    Thanks
    • knarfer's avatar
      knarfer
      Hi,
      we use brand new stacking cables and sfp modules
      regards
      Frank
      • Hopchen's avatar
        Hopchen
        Prodigy
        Hi again,
        In almost all instances, stack-port errors is a cause of either bad cables or bad modules. I suggest you reach out to support and let them have a look. If these are Netgear modules, they can look into an RMA if needed.
        You can log a case via: https://my.netgear.com/registration/login.aspx
        Cheers
