jg1
Nov 14, 2016Aspirant
M4300 VMware VLANS
I'm new to VLANs and having trouble configuring VLANs for use with VMware. Here's what I'm testing with: VMware standard vSwtich with a VM Network Port Group connect to a single vNic con...
- Nov 15, 2016
Hi Jg,
It's all right.
Any post about your concern is welcome:smileyhappy:
So the question now is "So if I have a single uplink connecting to another switch, that connects to the LAN for which I have no control over, and should not have any vlan config going out, how should that be configured? "
I want to summarize the topology from your information:
1) The port connect to VSwitches should be Tag mode.
This port maybe use multiple VLAN.(My example: port 1/0/2,Tag with VLAN 100,VLAN member 100)
2) The port connect as uplink to another switch should be unTag.(My example: port 1/0/4, PVID 100,untag with VLAN 100,VLAN member 100)
Please check the example as below:
In this topology,
multiple VLAN traffic will not forward two-way.
because 1/0/4 will only forward the untag packets to PVID VLAN 100.
Let me know your complete network requirement if you have further concern.
Again, any post is welcome.:smileyhappy:
Daniel.
DanielZhang
Nov 14, 2016NETGEAR Expert
Hi Jg,
Welcome to NETGEAR community!:smileyhappy:
Maybe the PVID configuration just missed on your M4300.
We also analyze your requirement carefully so let me clear your concern with a real vSwitch configuration example.
Please refer below's configuration example just like yours.
In this example,
1) There are three VM machine VM1,VM2,VM3.
VM1 and VM2 could communicate with each other but they can't reach the network of VM3.
VM1 and VM2 could communicate with Server A and Server C through VLAN 888.
VM3 could communicate with Server B and Server C through VLAN 999.
(Server C need to support VLAN tag feature on network adapter)
2) Configure VLAN information on M4300 as below picture:
You can select the VLAN mode by yourself.(general or access/trunk)
For the ports which forward untag traffic:
switchport mode general
vlan pvid xxx
vlan participation exclude 1
vlan participation include xxx
Or
switchport mode access
switchport access vlan xxx
For the ports which forward tag traffic:
Switchport mode general
vlan participation include xxx,yyy
vlan tagging xxx,yyyy
Or
Switchport mode Trunk
switchport trunk allowed vlan xxx,yyy
3) You also need to configure port group on vSwitch:
Let us know if you have further concern.:smileyhappy:
Daniel.
