jg1's avatar
jg1
M4300 VMware VLANS
      I'm new to VLANs and having trouble configuring VLANs for use with VMware. Here's what I'm testing with:   VMware standard vSwtich with a VM Network Port Group connect to a single vNic con...
  • DanielZhang's avatar
    Nov 15, 2016
    Hi Jg,
    It's all right.
    Any post about your concern is welcome:smileyhappy:
    So the question now is "So if I have a single uplink connecting to another switch, that connects to the LAN for which I have no control over, and should not have any vlan config going out, how should that be configured? "
    I want to summarize the topology from your information:
    1) The port connect to VSwitches should be Tag mode.
    This port maybe use multiple VLAN.(My example: port 1/0/2,Tag with  VLAN 100,VLAN member 100)
    2) The port connect as uplink to another switch should be unTag.(My example: port 1/0/4, PVID 100,untag with VLAN 100,VLAN member 100)
    Please check the example as below:
    In this topology,
    multiple VLAN traffic will not forward two-way.
    because 1/0/4 will only forward the untag packets to PVID VLAN 100.
    Let me know your complete network requirement if you have further concern.
    Again, any post is welcome.:smileyhappy:
    Daniel.
ProSupport for Business
