NGswUser23
Apr 25, 2024Aspirant
m4500 - Idle power / idle noise level - not listed in specs (M4500-48XF8C)
I realize this is a top of the line switch and not expected to be quiet or low power draw, however the only information I can find in the PDF spec sheet are the maximums (ie: max power draw w all por...
- May 02, 2024
to update my own post (as i still could not find this information anywhere); i got the m4500 switch in (48 port model) and:
from my own testing it's around 127 watts idle and 50 to 55 decibel sound level (pretty quiet for this level of switch)
NB: this is with both PSUs connected to mains, and NO OPTICS connected at all, yet. so is totally idle.
NGswUser23
thanks for the reply / info - ~100w is also what I would estimate myself around idle load. Also your reply below also answered a question I had as well:
There is no user command for configuring the fans; instead the low level management is adapting the fan speed (up to 100%) to the load
My only follow up is if any users have a m4500 deployed/in-use and could please comment on either the fan noise or power use in their actual experience I would appreciate it.
Thank you!
NGswUser23
May 02, 2024Aspirant
