twalt123's avatar
Oct 21, 2022
M4500-48XF8C Factory Reset w/o Password
Hello, I am trying to factory reset my M4500-48XF8C switch to prepare for a new firmware update but I do not have the password, and cannot seem to find a way to do that without the password to login...
  • twalt123's avatar
    twalt123
    Oct 25, 2022
    For anyone having this problem in the future who doesn't have experience with ONIE follow these steps.
    1. Reboot the switch and when you see the GRUB menu select "ONIE"
    2. Select "Uninstall NOS"
    3. Wait for it to clear all the hard drives in the switch
    4. When the switch reboots select "Install NOS" with the proper image on the root of a USB drive in the switch. The image needs to be renamed "onie-installer". I found I could only install the image named "onie-installer-x86_64-netgear_m4500-48xf8c_dnv-7.0.1.6" as it is the unsigned intermediate image and then I could update to the latest image.
ProSupport for Business
