gn00347026's avatar
Apr 03, 2023
M4500 (csm4532) , the BMD LED shows amber
Hi Everyone
I've two M4500-32C, one of it, the BMC LED show amber and blinking, any one know the reason? I use "show bmc" via the cli, both settings are the same. thank you.
      • sinanjp's avatar
        sinanjp
        Initiate
        For anybody looking for the answer to this in the future (as I guess OP already figured this out):
        You need to plug in both PSU.
        I had the same problem and found literally nothing on this, except for this thread. The manual also doesn't mention this.
        I called support and they told me to plug in both PSU, which solved the issue.
ProSupport for Business
