pbrady
Oct 24, 2015Aspirant
M5300-28G3 Management VLAN Disable Routing
Hey, I'm testing a stack of M5300-G3 switches with the 11.x firmware and just cannot get the managment VLAN figured out. It seems that whatever I do the managment VLAN becomes a routing VLAN - w...
- Oct 27, 2015
Hi pbrady,
I regret to inform you that the method in the v10.x firmware of having a non-routable management VLAN is no longer available in the v11.x firmware. With regard to this, it would be best to implement Access Control Lists or ACLs to restrict unwanted traffic to/from the management VLAN using the v11.x firmware.
DaneA
NETGEAR Community Team
DaneA
Oct 27, 2015NETGEAR Employee Retired
Hi pbrady,
DaneA
- pbradyOct 27, 2015Aspirant
No need to apologise - firmware series changes are a chance for vendors to implement changes. Its just this was not clear from my reading of the V11 documentation.
Is the management VLAN then a full routing VLAN the same as any other VLAN?
If I adjust the routing and ACLs across my network I can use the M5300, with ACLs, as the gateway to my other devices on the secure VLAN?
Thanks in advance,
-pete
- DaneAOct 28, 2015NETGEAR Employee Retired
Hi pbrady,
Yes.
The VLAN interface will act as the default gateway for the device in that VLAN.
DaneA
- pbradyOct 31, 2015Aspirant
Thanks DaneA, this has fixed the problem for me. Now just fine tuning the ACLs for full access.
Thanks again,
-pete
