ITK_Staud's avatar
ITK_Staud
M5300-52G-POE+ // Port does not come up - Port programming failed with error 0x1 for event OPERATION
Hi Community,
I have a GSM7252PS switch which worked fine for some months now.
Since a few days the 10GBit/s uplink (via SFP AXM761) isn't coming up anymore.
We tried
- different SFP
- different patch-cable
- different fiber
on both ends.
The SFP is in port 49 - another SFP in port 50 is working without problems.
The switch is running the actual firmware release 11.0.0.23.
When looking into the switch log I see the following errors:
<13> Jan 2 06:22:47 Studio-ACC-SW1 (1)-1 TRAPMGR[trapTask]: traputil.c(735) 871 %% Link Up: 1/0/48
<11> Jan 2 06:22:40 Studio-ACC-SW1 (1)-1 BOXSERV[boxs Req]: boxs.c(1445) 870 %% 1/0/49 Port programming failed with error 0x1 for event OPERATIONAL. Port may not be Up.
Any idea what could be wrong and how this could be resolved?
If you need further information just let me know.
Thanks a lot in advance,
Martin
  • Hi ITK_Staud,
    Welcome to NETGEAR community :smileyhappy:
    According to the error log just you mentioned.
    Maybe it's a hardware maturing or I2C missing.
    We will let you know the result after finishing code debugging locally.
    So please try port 50 as temporary work around way.
    Otherwise,
    Could you please get important diagnosis information on GSM7252PS for us?
    You can Input following commands in CLI mode to get diagnosis information
    show environment
    show fiber-port optics-info all
    show fiber-port optics all
    show fiber-port optics-eeprom all
    show logging buffered
    • ITK_Staud's avatar
      ITK_Staud
      Hi Daniel,
      thanks for your reply.
      Here is the output of the CLI you requested:
      (M5300-52G-POE+) #show environment
      Temp (C)....................................... 31
      Temperature traps range: 0 to 90 degrees (Celsius)
      Temperature Sensors:
      Unit     Sensor  Description       Temp (C)    State           Max_Temp (C)
      1        1       System            31          Normal          32
      Fans:
      Unit Fan Description    Type      Speed         Duty level    State
      1    1   CPU 1          Fixed     Not Supported Not Supported Operational
      1    2   CPU 2          Fixed     Not Supported Not Supported Operational
      1    3   Power 1        Fixed     Not Supported Not Supported Operational
      1    4   Power 2        Fixed     Not Supported Not Supported Operational
      Power Modules:
      Unit     Power supply   Description        Type          State
      1        1              AC                 Fixed         Operational
      1        2              RPS                Removable     Not present
      RPS
      Unit   Status             Power Module       RPS Port ID
      1      Not present        Not present        1
      (M5300-52G-POE+) #show fiber-ports optics-info all
                               Link Link                                 Nominal
                             Length Length                                   Bit
                               50um 62.5um                                  Rate
      Port     Vendor Name      [m] [m]  Serial Number    Part Number     [Mbps] Rev  Compliance
      1/0/49   NETGEAR          8   3    2F71373C06790    AXM761           10300   20 10GBase-SR
      1/0/50   NETGEAR          8   3    2F71373C06794    AXM761           10300   20 10GBase-SR
      (M5300-52G-POE+) #
      (M5300-52G-POE+) #show fiber-ports optics all
                                          Output    Input
      Port      Temp  Voltage  Current     Power    Power   TX     LOS  Fault
                 [C]   [Volt]     [mA]     [dBm]    [dBm]   Fault       Status
      1/0/49    26.4    3.264      5.0    -2.351   -2.425   No     No   No Fault
      1/0/50    26.4    3.267      6.0    -2.217   -2.548   No     No   No Fault
      (M5300-52G-POE+) #show fiber-ports optics-eeprom all
      Port 1/0/49
      vendor_name = NETGEAR
      vendor_sn   = 2F71373C06790
      date_code   = 130818
      vendor_pn   = AXM761
      vendor_rev  = 20
      eeprom data =
      03 04 07 10 00 00 00 00 00 00 00 06 67 00 00 00     ............g...
      08 03 00 1e 4e 45 54 47 45 41 52 20 20 20 20 20     ....NETGEAR
      20 20 20 20 00 00 09 5b 41 58 4d 37 36 31 20 20         ...[AXM761
      20 20 20 20 20 20 20 20 32 30 00 00 03 52 00 b9             20...R..
      00 1a 00 00 32 46 37 31 33 37 33 43 30 36 37 39     ....2F71373C0679
      30 20 20 20 31 33 30 38 31 38 20 20 68 f0 05 12     0   130818  h...
      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     ................
      ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff     ................
      Port 1/0/50
      vendor_sn   = 2F71373C06794
      date_code   = 130818
      vendor_pn   = AXM761
      vendor_rev  = 20
      eeprom data =
      34 20 20 20 31 33 30 38 31 38 20 20 68 f0 05 16     4   130818  h...
      (M5300-52G-POE+) #
      I also created a tech-support file which I can send you if like to have it.
      Thanks a lot for your help and best regards,
      Martin
