TWilson's avatar
TWilson
M7100-24 (XSM7224) Rack Mount kit
Does anyone know the Netgear PN for the M7100-24X (XSM7224) Rack Mount Kit and where I may be able to purchase 2 or 3 kits from?  Netgear doesn't appear to sell these.
So far my Google search has only turned up one that is compatible but which is also unfortunately no longer available purchase anywhere (Magnaroute GS-17 Rack Mount Kit Compatible with NETGEAR GS748TPS, XSM7224, and XSM7224S switches).
  • JulienR's avatar
    JulienR
    Administrator
    Hi TWilson,
    You have the option to purchase rackmount kits by reaching out to our technical support team.
    The rackmount kits part numbers 420-10075-01 and 422-10059-01 are compatible with the XSM7224.
    I'll get someone to reach out to you.
    Best Regards,
    Julien R
ProSupport for Business
