mechalas
Mar 18, 2020Aspirant
M7100-24X does RADIUS auth but no acccounting
We have an M7100-24X (11.0.0.31 firmware) configured to do RADIUS AAA on all auth lists for the management console. It does the authentication part just fine, but it never sends any accounting packet...
DaneA
Mar 19, 2020NETGEAR Employee Retired
Welcome to the community! :)
As far as I have checked, there is no issue logged on the M7100-24X as per described on your post. Not sure if this will help but let us try this. Kindly try to update the firmware of the M7100-24X to the latest version which v11.0.0.40 then observe if the same problem will occur. You can download firmware v11.0.0.40 here.
DaneA
NETGEAR Community Team
- mechalasMar 19, 2020Aspirant
We don't update firmware on a whim. It's an event that impacts users. The changelog for this firmware suggests the only change was this:
- Compliant with California Privacy Law: Force user to change the default password on first login to the device.
Unless you have a better argument for why you think this firmware will resolve the issue, then no, I am not going to take down a bunch of users for a non-essential change.
