wwoltmann's avatar
wwoltmann
Managed switch
Is there a 5-port managed switch that will allow me to force gigabit speeds?
  • JohnC_V's avatar
    JohnC_V
    Jul 25, 2018
    wwoltmann,
    Where are you getting that speed? What tools are you using to test it? If you really want to know the throughput of the ports then you may need to use JPerf, bandwidth is different from port speed. NETGEAR doesn't have a 5-port switch that can manually set the port speed to 1G.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi wwoltmann,
    Welcome to our community! :)
    Unfortunately, GS105Ev2 can only be forced to 10M and 100M. However, if the port speed is set to "Auto" and your PC is capable with 1000Mbps, it should show "1000M Full" on the Linked Speed column.
    • wwoltmann's avatar
      wwoltmann
      No PC’s will be directly attached.  I’m working on my WiFi environment in my campground.  The radios are said to have gigabit ports but when doing a speed test between radios that are hardwired together I get about 200Mbps, when I place a unmanaged gigabit switch between them I get 360 Mbps.  The radios are negotiating to a slower speed, I need a switch where I can force the port speed to gigabit.
      I have 15 AP’s hardwired to bridges that use 5GHZ back hall to a controller.  I’m losing to much bandwidth due to auto negotiation.
      • JohnC_V's avatar
        JohnC_V
        wwoltmann,
ProSupport for Business
