AGJECAJ
Nov 23, 2018Aspirant
Mikrotik and Netgear M5300 LAG
Hello,
I am trying to configure Link Agregation between Mikrotik CCR1036 and Netgear M5300
My traffic in Mikrotik is going more than 1gbps so i thoung i could use LAG and make my uplink to 2gbps....
schumaku
Nov 23, 2018Guru - Experienced User
AGJECAJ wrote:
After i configured sfp1 and sfp2 to bondig 802.3ad and in Netgear sfp45 and sfp46 sometimes it show in one interface upload and other interface download, ...
Reads like the common confusion. There is nothing wrong with what looks like an asymmetrical data transfer, it's up to the sending side which of the physical links is used in a trunk.
AGJECAJ wrote:
and does not make mt link to gbps, i have tested and is only 1gbps.
Are both switches show that the LAG are up on both sides?
Screenshots are showing peanut traffic only, nothing near to a point where one physical link is near to 1 Gb/s.
AGJECAJ
Hello,
As you see in netgear photo i have checked port 45 and 46,
Screenshot is taken in the 3pm, at 8-9 pm traffic is at 900mbps, im thinking about th3 future traffic,
Should it make traffic in both ports or after sfp1 goes full, sfp2 gets the other traffic?
Im getting confused for configurations on l2 l3 and srcmac dstmac vlan in netgear and mikrotik, is anything wrong in configuration?
Thank You
Thank You
