AGJECAJ
Nov 23, 2018Aspirant
Mikrotik and Netgear M5300 LAG
Hello,
I am trying to configure Link Agregation between Mikrotik CCR1036 and Netgear M5300
My traffic in Mikrotik is going more than 1gbps so i thoung i could use LAG and make my uplink to 2gbps....
AGJECAJ
Hello,
As you see in netgear photo i have checked port 45 and 46,
Screenshot is taken in the 3pm, at 8-9 pm traffic is at 900mbps, im thinking about th3 future traffic,
Should it make traffic in both ports or after sfp1 goes full, sfp2 gets the other traffic?
Im getting confused for configurations on l2 l3 and srcmac dstmac vlan in netgear and mikrotik, is anything wrong in configuration?
Thank You
Thank You
schumaku
Nov 23, 2018Guru - Experienced User
Still no reason, one GbE is sufficient for 900Mb/s.
Again, that's why I said the typical confusion: You will see that each direction is handled mainly by one port, and only once there is more traffic, the additional ports are used. It's in no way something like a link load balancing.
Config is for the transmit policy by switch only.
