Rajita
Feb 15, 2019Aspirant
Multicast issues with M4100-26G v2
Hi,
I am trying to implement multicast using IGMP snooping. I am using single switch and 2 systems (1 for multicast client and 1 for multicast server)I have following setup of switch:
In switchin...
DaneA
Feb 18, 2019NETGEAR Employee Retired
Hi Rajita,
Welcome to the community! :)
Based from the image posted, v10.0.2.20 the current firmware version of the M4100-26Gv2. I suggest you to upgrade the firmware of the M4100-26Gv2 to the latest version which is v10.0.2.26. You can download it here. Then check if the same problem will occur.
Also, kindly post an image or screenshot of your detailed network setup.
DaneA
NETGEAR Community Team
