CChildrenIT
Sep 11, 2018Aspirant
mynetgear registrations are missing.
When I log into MyNETGEAR, I don't have any switches registered. I called NetGEAR a couple of weeks back to see what has happened, and was told that it's an issue that they know about. I've tried aga...
JohnC_V
Sep 11, 2018NETGEAR Employee Retired
Hi CChildrenIT,
Welcome to our community! :)
We do really apologize for the inconvenience this may have caused you. We do are still in a process of fixing this issue. We assure you that your registered devices will show on your account by the time it was resolved. I'll send you a pm.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
