PoPPop77's avatar
PoPPop77
Nec SV8100 Phone System and GS728TP v3 QOS
I am needing help setting up my GS728TP and GS748Tv3 Switch Settings so that they will pass the Nec SV8100 Phone System packets. My issue is that I have a EnGenius ENH 500 Wireless WDS Bridge between two buildings and Something is wrong that my NEC VoIP Phones keeping Logging off randomly. Here is the error in the Netgear GS728TP Log: LLDP-N-LLDP_TRAP: LLDP status: entry deleted on ifindex g9. If I change the Nec SV8100 Phone system Subscribe Expiry time from 3600 (default) to 180 the problem goes away but according to NEC is just a workaround and is not advisable do to the extra strain on the phone system CPU. We setup QOS to DSCP and I think its set it up so that the IP precedence is Level 5. There no Vlans setup and I wouldn't even try with my limited knowledge of these switches. Anyone have any suggestions Please?
  • Just curious but can you phone without bridge wireless? phone straight to switch?
    WDS cuts the performance so you may want to isolate from there.
  • The buildings are separated by 60 feet so I cannot bypass the wireless bridge but thank you for the suggestion.
ProSupport for Business
