Fred2634
Jan 11, 2018Aspirant
Need 24 port POE 16 watts per port managed (Gigibit)
New to community......Looking for the best solution for a 24 port POE Gigibit switch with 16W per port and managed. Want to be able to re-boot each port and the switch remotely. We will have 3 of the...
- Jan 15, 2018
Thanks for the reply John. Our project includes 3 cabinets located 30' at ceiling level in a warehouse where the POE switches will be installed (24 port) for the IP cameras. The cameras will require up to 16V. If we need to reboot a camera and or the complete switch through the IP address of the switch, is what we are looking for. From what I understand this would be a managed switch ........... that we can "manage". There are 3 switches connected together throughout the warehouse (cascaded together) with 1 CAT5 cable going to the headend room to manage switches. Can you recomend a switch that will do this?
Thanks,
Fred
Yes, you are correct. If you wanted a switch that has a remote management, then the least that I can suggest is the M4300 series. Just put a check on the lower left corner, "POE+ up to 30w per port" so that you can filter the POE switches.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Fred2634
Jan 13, 2018Aspirant
Thanks,
Fred
JohnC_V
Jan 15, 2018NETGEAR Employee Retired
Thanks,
Fred
