ecsrun27's avatar
ecsrun27
Netgear enterprise switches & LLDP PortID
Below is the 'lldpctl' output from a Linux host connected to a Netgear M4300. Why does the 'PortID' get the word 'local' as a refix?  This is wreaking havoc on some of our switch monitoring software. Cisco, Arista and others just show the PortID like 1/0/1, etc. Juniper uses the word local but they have the ability to customize this PortID string so that it can be removed.
Interface:    eth1, via: LLDP, RID: 2, Time: 0 day, 00:00:11
  Chassis:
    ChassisID:    mac 10:da:43:f9:3b:3d
    SysName:      M4300
    SysDescr:     M4300-8X8F ProSAFE 8-port 10GBASE-T and 8-port 10G SFP+, 12.0.2.20, 1.0.0.9
    TTL:          120
    MgmtIP:       10.0.103.1
    Capability:   Bridge, on
    Capability:   Router, on
  Port:
    PortID:       local 1/0/5
    PortDescr:    1/0/5
Any help would be greatly appreciated!
  • Apparently the LLDP-MED feature changes the portID sub-type from 'ifname' to 'local'. I found this just by some luck in that I disabled LLDP-MED. Here is a Linux host running lldpctl when LLDP-MED is turned on:
    [root@NTNX-14SM36451141-A ~]# lldpctl
    LLDP neighbors:
    Interface:    eth0, via: LLDP, RID: 1, Time: 0 day, 00:15:42
      Chassis:
        SysName:      M4300
        TTL:          120
        MgmtIP:       10.0.103.1
      Port:
        PortID:       local 1/0/2
        PortDescr:    1/0/2
    And here it is with LLDP-MED disabled:
    LLDP neighbors:
    Interface:    eth0, via: CDPv2, RID: 2, Time: 0 day, 00:25:25
      Chassis:
        ChassisID:    local 4G346A7B800F3
        SysName:      4G346A7B800F3
        SysDescr:     M4300-8X8F running on
                      12.0.2.20
        TTL:          180
        MgmtIP:       192.168.201.2
        MgmtIP:       10.0.103.1
        MgmtIP:       10.0.104.1
        MgmtIP:       10.0.105.1
      Port:
        PortID:       ifname 1/0/2
        PortDescr:    1/0/2
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi ecsrun27,
      It would be best that you open a chat or online case with NETGEAR Support at anytime regarding your concern.  This will be escalated to the engineering team for further investigation.
      DaneA
      NETGEAR Community Team
ProSupport for Business
