Orktom
Nov 18, 2022Aspirant
netgear gs724t all LEDs are lit
Hello, After starting all the led candle reset nothing gives what you can still do? 😞
Nov 19, 2022Guru - Experienced User
All the led's are lit? Is it working at all?
there wasn't much to your description.
HARDWARE WARRANTY | PRODUCTS COVERED BY WARRANTY | NETGEAR
- OrktomNov 20, 2022Aspirant
so they all shine all the time unfortunately the switch does not work can not be logged in, reset to factory settings also nothing
😞 Previously did not shine as the switch started correctly- schumakuNov 20, 2022Guru - Experienced User
Head to https://my.netgear.com/ check [My Registered Products] for the warranty status. This is the hint plemans gave before.
