  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    ManuelGarcia3,
    Welcome to the community! 🙂
    Is possible apply a configuration backup of Netgear GS724T to Netgear GSM4328PA?
    No.  You might brick the GSM4328PA if you upload the configuration backup of the GS724T into it.
    DaneA
    NETGEAR Community Team
    • ManuelGarcia3's avatar
      ManuelGarcia3
      OK DaneA, Thank you very much by the tip.
      Its a pleasure to belong Community Netgear!!
      Understand that i need create a new configuration on GSM4328PSA.
      Any cookbook or technical sheet to configure this switch?.
      Is my fisrt implementatión and is very basic, only need make a LAN whith a 7 PCs windows. Is more or less as a  HUB config, that all devices see and communicate and also the management console UI of the switch on the same network.
      Regards!!!
ProSupport for Business
