tommiedepommie
Jun 14, 2023Aspirant
Netgear GS724TS
Hello, I have a Qnap ts-453Be NAS which support trunking. I also have a Netgear GS724TS v1 with boot version 1.0.1.5 and software version V5.2.0.11 Can I use this switch to configure port...
schumaku
Jun 15, 2023Guru - Experienced User
Hi Tom,
Unless I'm wrong, the GS724TS does support static LAG and dynamic LACP LAG configurations.
-Kurt
- tommiedepommieJun 16, 2023Aspirant
Hello Kurt,
I've tried to configure the LAG on my GS724TS but the existing manual I've found, is completely different than my software in my switch.
Do you have a corresponding manual how to configure the LAG in my switch?
Thank you,
Tom
- schumakuJun 16, 2023Guru - Experienced UserOnly what is published and available I'm afraid.
Can you please post some screenshots of what you see there?
Talking of the device embedded Web UI, or from the Windows application related?- tommiedepommieJun 16, 2023Aspirant
Hello, I'm missing the window where I can select the ports.
- schumakuJun 16, 2023Guru - Experienced UserIgnore - duplicated reply
