Mansin
May 20, 2019Aspirant
Netgear GS748T VLAN Tagging
Hi,
All of our managed switches are Netgear and majority are GS748T. I've been successfully adding VLANs and assigning memeberships. I've now come to one of the GS748Ts and when tagging a port ...
- May 20, 2019
Is this a port probably also member of a LAG? Have spotted that some models/firmware are not properly masking/hiding the tag information on the port level if these are also a member of a LAG.
schumaku
May 20, 2019Guru - Experienced User
Mansin
Thank you for your input. It was the fact that the port was part of a LAG. So now I've tagged the LAG instead of the port.
Thank you
