Rhino58
Jul 16, 2018Aspirant
Netgear GS748Tv3 switch – can I plug a 10GB SFP+ Direct Attach Cable into the input. Will it work.
Hi
New to switches. Trying to see if our switch is the bottleneck.
Paul
JohnC_V
Jul 18, 2018NETGEAR Employee Retired
Hi Rhino58,
Welcome to our community! :)
Unfortunately, GS748Tv3 is one of our old units that only supports 1000BASE-SX / LX SFP GBIC module. The only module that you can use is the AGM731F / AGM732F.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
