DRL
May 06, 2015Aspirant
Netgear GS752TPS Slow after stack master election.
I have two GS752TPS switches stacked together using the standard Netgear stacking cable. An issue occurred after a power failure that resulted in the stack master rebooting and the second stack membe...
DRL
May 07, 2015Aspirant
The firmware is version 5.3.0.17. No I didn't test with the stack/switches disjoined from each other. I have 150 users connected through this stack and that's not possible. Anyway, the problem went away immediately after manually changing the stack master back to Switch 1 so I can't test anymore. I'm more posting this question to 1. Make users of the forum aware that this could be an issue they're having and to check this on their switch if an election happens and 2. to see if this is as designed by Netgear as some sort of fail-safe action to keep the switch running after a failure of the stack master. If this isn't by design and is a bug then all this post will be good for is to alert other users to check this if they notice one of their switches running very slow throughput.
Thanks
Thanks
