IT_VBO
Oct 30, 2015Aspirant
netgear GSM7352s byte error crc check firmware
Hello, I have a netgear GSM7352s (v1) giving me every time with every firmware versions an netgear "1byte error crc" after uploading the firmware throug Xmodem (extra putty). http://kb.netgear...
IT_VBO
Nov 10, 2015Aspirant
Hello,
On KB http://kb.netgear.com/app/answers/detail/a_id/22
"For GSM73xxS, instead of using the firmware images available on the NETGEAR support site, first obtain the file “gsm73xs-6.2.0.6.opr” available from URL ftp://downloads.netgear.com/files/gsm73xxs-6.2.0.6.opr. Then, use the following procedure to load the switch with that file. After reboot the switch, upgrade to the 6.3.x.x firmware normally using either TFTP or HTTP from WEB interface, or copy command from CLI. The file “gsm73xxs-6.2.0.6.opr” should only be used for loading the switch using XMODEM and serial console. Do NOT use the file for normal firmware upgrade using TFTP."
Where i can get the “gsm73xxs-6.2.0.6.opr” file please ?
Maybe this is the solution...
