Hisin-YI
Apr 01, 2024Aspirant
NETGEAR M4250-10G2XF-PoE++ (GSM4212UX)_lldpcli Command setting issue
Hello, Thank you for any help or advice in advance. Under M4250 CLI Command Mode to check the status of POE, it always shows the maximum power watt:99W)_below picture I want to know which comman...
schumaku
Apr 02, 2024Guru - Experienced User
Not sure what you expect.
The switch PoE circuitry isn't limiting the power to what the PD does request, the max available is still 99.9W (due to regulatory definitions max. under 100 Watts), permitting the switch has enough power available within it's total power available.
If you have a wall outlet of 120V and 15 Amps, connect a heater 1500 Watt heater, drawing 12.5 Amps, the outlet is still 1800 Watts.
If requesting 15.0 W resp. 25.5 W from the PSE, the PD does get a credit reservation of the requested amount of power. If draws 15.066 W, this is more than what you have reserved with 15.0 W. Review your PD hardware (or for the sake of it your test case).
