tantony
Oct 24, 2018Luminary
Netgear switch dhcp
I have two Netgear switches (XS716T and XS728T) connected to a Juniper firewall. When I connect the laptops to the switches, sometimes I get the incorrect dhcp and default gateway. I called Juniper, and after 2 hours they said it's the switch causing the issue because I can see the switch making dhcp request.
How do I stop the Netgear switches from making dhcp decisions?
Check the switch and disable any DHCP snooping, DCHP static bindings, DHCP snooping persistent entries, ...
- tantonyLuminary
so far, I'm only seeing DHCP snooping, and disabled on both switches. I think I'm having the same issue, I'll double check tomorrow.
I don't have any static bindings etc.
I ran WireShark, and I can see the switches handling dhcp instead of the firewall for some reason.
Operating bunches of XS7xxT in core, backhaul, and device access with customers and here at home/office. All fully DHCP transparent, all DHCP is handled by the designated systems for the various VLANs (some on similar security appliances, some on Windows AD Servers) in a transparent way (with hundreds of systems/devices btw.).
Proabbly time for a factory reset and a manul reconfig from scratch?
Without more insight it's hard to help.
