ikatutu
Jun 09, 2016Aspirant
Netgear XS708e connecting to cisco Catalyst 2960
Hi guys I bought a Netgear XS708Ev2|ProSafe Plus 10G 8 ports switch to put it with our cisco network, but I am having trouble connecting it to cisco catalyst 2960 Is anybody work with this specific...
- Jun 16, 2016
Thanks for your help... I did put T on the direct port toward cisco switch with PVID of 1 and a member of all vlan, and still not working... so i decided to put the netgear as a dump switch and put native vlan 5 on my cisco switch to point to the management ip address of the netgear which within a management subnet address... and works fine...
I am still looking on why it was not working with putting T on a port with PVID = 1 and All vlans.
but thanks again for your help.
DaneA
Jun 15, 2016NETGEAR Employee Retired
Hi ikatutu,
Feel free to post your questions.
DaneA
NETGEAR Community Team
ikatutu
Jun 16, 2016Aspirant
- DaneAJun 16, 2016NETGEAR Employee Retired
Hi ikatutu,
I'm glad to know that it works fine. :) I appreciate that you've shared what the steps you've done.
Since the problem is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
