t_SOMAS
Aug 23, 2016Aspirant
netgear XSM7224S connectivity issue frequently getting RTOs from host end
Hi,
getting an error how to reslove please help me out here.
<14> JAN 08 09:26:20 169.254.100.100-1 ARP[-1968122880]: ipmap_arp_api.c(1235) 3048 %% ARP hash collision. Reducing ARP cache from 69 to 68 entries in 0 msec.
- JohnRoNETGEAR Employee Retired
Hello t_SOMAS,
Welcome to the community!
I believe it will be a big help if you include some more information. I have listed some needed details below:
- Firmware version of the switch.
- Simple network diagram.
- Changes made on the network prior to experiencing the issue.
- Changes made after experiencing the issue.
- How often does the error show.
Thanks,
- DaneANETGEAR Employee Retired
Hi t_SOMAS,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- t_SOMASAspirant
the version is 9.0.1.29
model no:XSM7224S
server >>>>>>>Access layer switch(XSM7224S)>>>>connected to >>>>>>>Distibution switch Cisco4948>>>>>>connected to>>>>>>6500cisco coreswitch
there is no changes made.
- LaurentMaNETGEAR Expert
Hi t-SOMAS
Please send us the Tech Support file by email to switch_support@netgear.com. Please don't forget to include a link to this post on the Community forum. With the Tech Support file, we will be better equipped to understand why you show retransmission timeouts from host end.
How to get the Tech Support file from your NETGEAR M7300 (XSM7224S) managed switch:
- First, please log in to the command line interface of the switch, and from enable mode, run the command: show tech-support. When done, you can proceed with the CLI method or the Web GUI method below.
- Using CLI, you can use the COPY command described in M7300 CLI manual on page 508/509, the file to copy is <<nvram:tech-support>>.
- Using the Web GUI, you can upload the Techsupport file by selecting Select Maintenance > Upload > HTTP File Upload for instance, as described in M7300 WEB manual on page 489.
