GutschalkD
Oct 30, 2020Follower
nms300 configuration backup failed
Hello everyone, I have a couple of Netgear M4300 switches in my network. Two 96X, some 28G and some 52G. They're all either running 12.0.11.13 or 12.0.11.15. I've installed NMS300 on a Windows 1...
Dan_Z
Nov 03, 2020NETGEAR Expert
Hi GutschalkD,
Are you use the same schedule to backup all devices? Recommend you try to use different schedule to backup the configuration.
Thanks.
- DGutschalkNov 23, 2020Tutor
First: Thank you for your reply.
Second: I'm very sorry, I was on vacation the week you posted and didn't have my password at home to log in and reply. When I was back in the office I simply forgot.
Now to your reply. I'm not using a schedule at all, I'm trying to backup configuration on demand right now. When it works I'll set up a schedule.
Kind Regards
