Orange_GT3's avatar
Orange_GT3
Backup Plex configuration
I am moving my Plex server from my ReadyNAS Ultra 4+ to another, newer, more powerful NAS.
I know what files and folders I need to copy across but when I go to set up a Backup job, I cannot select the folder I need as only my Shares are visible.
How do choose the Plex config folder which is located under '\\NAS-name\data\.apps\plexmediaserver'?
I'm running OS 6.10.3.
Many thanks in advance.
  • If you know how to run rsync from the linux command line (ssh), you could transfer the folder to the destination NAS w/o using a backup job.
    Another option with ssh, is to copy the plexmediaserver folder into a share.  Alternatively create a zip the folder in a share (which will copy over the network much faster).
    You can also of course drag and drop to the destination.  That will be slower, but doesn't require any knowledge of linux.
  • StephenB's avatar
ProSupport for Business
