Sam_CL
Aug 11, 2021Tutor
NMS300 Terrible Since Upgrading from Flash
Is anyone else having problems with NMS300 since it went from Flash to HTML5? The map functionality has been useless since this update. I've given it every update since the change hoping that it was ...
DaneA
Aug 12, 2021NETGEAR Employee Retired
Kindly answer the questions below:
1. On what Operating System is the NMS300 installed?
2. What is the current version of the NMS300 you have?
3. Are there any error messages you have encountered? If yes, kindly post a screenshot of it.
DaneA
NETGEAR Community Team
- Sam_CLAug 12, 2021Tutor
Hi
No errors coming up, the map is slow to load and everything is way too big. To the point where it's just a jumbled word mess that is pretty much illegible. Tried multiple browsers, multiple devices and scaling options to get the same result.
It's installed on a Windows 10 VM. If I recall correctly it's on 20h2 as thats a long term support build. The flash version once it loaded, was fine.
As for the version I think one of the technicians updated it a week or 2 ago so should be current or version behind. Away from site at the moment so once i'm back I shall take another look
