vabulldog's avatar
vabulldog
No internet when using a VLAN port
I have 2 ports that are on VLAN 90 (not the default vlan). My switch is does not have a DHCP server so I have to manually change the IP to put them on the same subnet. They both have an 192.168.90.xxx IP address when I do this their network icon turns into a globe and they do not have internet access.
Is there anything I have to do after setting up the VLAN to allow these devices to access the internet (possibly routing)? Both devices can ping each out and the switch GUI at 192.168.90.1.
This entry was added to my routing table when I created the VLANS.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    @vabulldog,
    How is everything connected?  It would be best if you post a detailed diagram of your existing network setup.
    DaneA
    NETGEAR Community Team
ProSupport for Business
