cookiesmonster
Aug 26, 2016Aspirant
Open managment website GS108T
Hi, I have 2 GS108T managed switches. Because i lost the password i found a Kb to set the switch to factory default. After the reset i can set a new password with the discovery tool but i cannot op...
- Aug 30, 2016
Hi,
I did a second factory reset of both switches.
They are both working fine now.
Can't explain why but i'm happy with the result.
Regards and thank you for your assistance.
JohnRo
Aug 26, 2016NETGEAR Employee Retired
Hi cookiesmonster,
Welcome to the community!
What is the error message you are getting? Are opening the web-ui using the utility or manually typing the address on a browser?
Thanks,
