gnah's avatar
gnah
GS108Tv2 - no firmware tab in management website
I have a GS108Tv2 and i'd like to upgrade the firmware. I only have linux machines, so the Smart Control Center does not work. I thought i could upgrade the firmware instead with http, so i browsed to the switch website, logged in, went to the maintenance tab but there is no firmware tab.
Is this feature only available with that windows application?
ps.: i unfortunately posted the same question (accidently) in https://community.netgear.com/t5/General-WiFi-Routers-Non/GS108Tv2-no-firmware-tab-in-management-website/m-p/2179530#M153478
  • Early Smart Managed Pro switches from launched more than a decade ago were initially fully depending on the utility (Smart Control Center), even older ones since the early 2000ands  used an even older utility (Smartwizard Utility). Some switch models got a limited Web UI over time as part of the ongoing development, some later ones got even a full Web administration complementing the utility.
    The only option is to run a WIndows VM or loan a Windows PC to run the utility required.
  • schumaku's avatar
    schumaku
    • gnah's avatar
      gnah
      thanks for that information! then i'll try to organize a windows machine and see if that works with the control center.
    • gnah's avatar
      gnah
      i can confirm that worked. so there is no way to upgrade the firmware without a windows system? i am asking because i am going to write my master thesis about automatic infrastructure recovery and if thats the case with the requirement of a running windows, this switch is unfortunately not useful. i am used to have some kind of management interface that is os independent (any API, web management or cli)
      • schumaku's avatar
        schumaku
        Welcome to the reality!
        Here you find many more devices which will cause you green field ideas big problems and headaches - devices like commercial/business grade switches and routers, devices with fixed default IP (you will have probably a hand full or hundreds on the same IPs) on the in-band management (any don't have this enabled from the factory reset), devices with out-of-band network management, devices with serial console ports, devices require tftp or even proprietary schemes to load and boot firmware and load configs, ... legacy devices requiring proprietary processes, tools, and utilities, ...
        What does the theoretical availbility of a CLI or a Web-access help if you can't reach these for various reasons?
ProSupport for Business
