billvo
Jan 16, 2018Aspirant
Password Recovery Procedure for GSM7224P?
I have no password for a switch I've just been assigned to manage. Factory default of admin with no password doesn't work. I need to recover the password for this switch. The procedure I found...
- Jan 16, 2018
I found that I needed to set HyperTerminal for Flow Control "None" instead of the default of "Hardware".
billvo
JohnC_V
Jan 17, 2018NETGEAR Employee Retired
Hi billvo,
Welcome to our community!
Is everything works ok now? Were you able to set it to factory default in order for you to reset the password?
- billvoJan 18, 2018Aspirant
Thanks! Yes, I was able to set a password and reset the switch to defaults.
I had overlooked the Flow Control specification in the procedure I referenced. The specified XON/XOFF may be correct, but Hardware Flow Control (default for HyperTerminal) does not work.
Bill
