ajlowe
Aug 20, 2015Aspirant
Please help me upgrade the firmware on GS748Tv3 and GS724T
In a small business environment I have 6 Netgear GS series switches of various ages. using Netgear Smart Control Center Manager version 1.1.3.2 I can connect to and update the firmware on the tw...
ajlowe
Aug 21, 2015Aspirant
Thank you for your help John.
I did a factory reset on all the switches.
I used the Smartwizard Utility you linked to.
I still can not discover any of the switches with the old firmware.
I am ignorant ofthe term SCCM. Can you please explain what that is?
JohnRo
Aug 21, 2015NETGEAR Employee Retired
Hi ajlowe,
Sorry, the SCCM is Smart Control Center Manager. There is another settings that you can check on the smart control center manager, under the adapter tab, make sure you are using the correct adapter of the PC and the IP address is correct. Please see example below:
Hope this helps, I'll look forward to your update.
Thanks,
