marks945's avatar
marks945
Follower
Jan 18, 2017
POE on GS108E
Hi
I'm just trying to get power over ethernet on my GS108E prosafe switch.
My understanding is that only some ports support POE. I do not see any markings and I looked in the config utility and do not see any options to enable the port.
How do I setup the port for POE?
Thanks
Mark
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi marks945,
    Welcome to the community! :)
    The GS108E switch model does not support PoE.  The GS108PE switch does support PoE.
    I recommend you the GS108PEv3.  The GS108PEv3 has 4 PoE ports with a total PoE power budget of 53 watts.  To know more about the GS108PEv3, kindly check the data sheet here which includes the comparison to other ProSAFE Gigabit Web Managed Plus Switches.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    marks945,
    Let us know if you have further questions.
    DaneA
  • DaneA's avatar
    DaneA
    marks945,
    We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
    If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
ProSupport for Business
