rudnicke
Apr 05, 2018Aspirant
PoE Question
I'm looking to implement a few UniFi cameras. I'm trying to find out if this switch will do 24v passive PoE. I'm not seeing anything in the documentation about what voltage it uses, and Google just...
JohnC_V
Apr 05, 2018NETGEAR Employee Retired
Hi rudnicke,
NETGEAR switches doesn't support passive POE and it only supports IEEE 802.3af/at.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
