jolek
Oct 02, 2017Follower
PoE switch concected to PoE switch connected to PoE needed accespoint
Can i connect a PoE switch behind a PoE switch in a row whit PoE enabled and put a PoE needed accespoint behind it ?
Is there danger for to much power on the enternet port for the accespoint?
switch model GS728TP (2x)
1 Reply
- LaurentMaNETGEAR Expert
Hi jolek
Welcome to the Community!
You are all fine, PoE switches are very safe and just don't deliver power when there is no need at the connected device(s). In your case, no PoE power will be delivered on the port where another PoE switch is connected to. Detection is happening port by port, automatically.
I hope this helps
